I wouldn't put anymore clarifier in. I would just be very consistant with keeping the chlorine level at shock for a couple of days. You should see your start to improve. If after a couple of days you don't see improvement, then you can use a floc.
Northeast PA
Thanks so much Marie! I will follow that course of action, bringing the chlorine up, and turning off the filter at night, and vacuuming. I will let you know how things look in a few days!!
Please keep posting your status. I have the EXACT same problem. "Dirt" settles to the bottom of my pool, but my chemistry seems okay. No algae seems to be growing anywhere so I think it's just sediment too. So, keep posting - I'm kinda following in your lead.
27,000 IG Vinyl
Aquarite SWG
Still Learning Everyday
Turning off the filter at night helps ALOT!! All of the stuff does settle down, and we are able to vacuum the stuff out. We have done this twice already, and the water is definitely bluer. We figure 2 more times, and then we will be good.
Only problem is, since we are vacuuming to waste so much, we now have to add water. Which I am terrified to do. I ordered a filter that you attach to your garden hose, which supposedly filters out the iron and copper before it gets to the pool. But this won't be here for at least a week
So, we may just have to bite the bullet, and add the well water again. Of course, I will add the metal out first, and hopefully, we won't start this vicious cycle all over again!
mariella, just make sure there is enough sequestering agent in the water. Add your fill water through the skimmer and you should be fine. When adding, just keep your ph on the low side.
Northeast PA
How low should the pH be, mbar? And, should the chlorine also be low?
I have to tell you, I am terrified about adding the new water! We finally have all of the stuff vacuumed, and the pool is BLUE!!
I don't want to go back to where I was, but we seriously have to add water.
Just keep your ph at 7.2, and add the water through the skimmer. You should be fine. If you see any stain start to form, just add more sequestering agent with the ph at 7.2 and it will take it away. Your chlorine can stay where it is. I remember how scared I was to get the stains back too - but now that you know to keep the ph low, and keep the sequestering agent in the water, you should be fine.
Northeast PA
