Results 1 to 10 of 18
Thread: Brown sediment and Green Water after Metal Treatment
    mbar's Avatar
    Ashland, PA
    Default Re: Brown sediment and Green Water after Metal Treatment
    Some metal removers need the ph to be high - I am currantly waiting for "Metal Magic" by Proteam, that Waterbear told me about. It is really supposed to "remove" metal from the water by turning the metal into crystals so they can be removed by the filter. I don't know if this really works or not - I will post when I try it. There is also something by "Jack's Magic" that is supposed to be used after the sequestering agent - I have to call there and speak to someone there today. I am still trying to find something that removes metals instead of just sequesterering them. I will post the info I get.
    I still have gotten the best results taking down the ph and adding the sequestering agent then the other way around. That's my experience. Hope this helps, and really hope we can find something that will get the metals out once and for all!
    Northeast PA
    Jul 2006
    Marie,
    The stuff that I use is SuperErace, made by Phoenix. I did q quick search on the internet, and this is all that I could find:
    Metal Out and Erace are metal sequesterers. {they block the metals from staining but do not take them out of the water} Super Erace and Metal Magic are actual metal removers. {they change the chemical composition of the metal to a crystal so that it can be filtered}
    I do know that, after I use the SuperErace, I get all that fine brown powder in the bottom of the pool. I am guessing that this powder is the "crystals"? My DE filter used to filter it out, but the cartridge filter does not, so that is why we have to vacuum to waste. (Have I mentioned that I hate the cartridge filter?)
    So, just in case this is one of those chemicals that needs a higher ph, I will keep the ph at 7.5. I am still mad at the pool store people, though. Rudeness is just not good customer service.
    mbar's Avatar
    Ashland, PA
    Yes, there is no excuse for rudeness! I understand your frustration with having to vacuum to waste - I hate when I have to do that too. Thanks for the info on super erase!
    Northeast PA
