Start with the stickies in this forum, in the Chlorine forum, the Chemistry and testing forum, and the pool chemicals and problems forum..
Moose,
Once you have tested your water - please post your numbers
FC (free Chlorine)
TC (total Chlorine)
PH
ALK
CA (Calcium)
CYA (stablizer)
Also include ALL the chemicals you have been adding. We can then help you get to a clear blue pool![]()
Completed 8/21/06
Spa with spillway
250K BTU gas heater (for spa)
SWCG - Aqua Rite
Another newbie to the site here.
Every link I find for the bleach Calculator is no good. I just found this great web site, and am having algea problems also. I am reading, and gathering info to post to see if I can get it under control..
TIA
Les
Les
Here is my calculator. It is an excel file. When you open it, you will have to unzip it.
Keep in mind the numbers are for my pool.
so just change the volume to match your pool size and then the chlorine amounts will automatically adjust for your pool size. Also if you are using a lower conc of bleach, adjust that too.
Andy
