Thread: Yellowish fittings-CL overdose???
    Default Yellowish fittings-CL overdose???
    it got really hot, then very cold here and I didn't adjust my inline cl feeder, and as a result, my cl went very high. I have a whitish liner with blue border and it didn't bleach it, but it took a while for the cl to come down.
    In the meantime, my main drain covers and eyeball fittings turned kinda yellowish....I thought that if I would have "bleached" them, they would have been white.......My liner is AOK just the plastic fittings turned yellowish.
    My steps are AOK.
    does anyone know how to get the fittings white again..? Thanks.
    Default Re: Yellowish fittings-CL overdose???
    If you got a yellowish stain when the chlorine levels were high I would suspect iron. Try holding a vitamin C tablet on the stain. If it is iron it will disappear in a very short time. If it does read the metals section of the forum for advice on using ascorbic acid to remove iron staining.
  1. Yellowish dirt
    By Barry J in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2012, 04:33 PM
  2. Old plastic water outlets and skimmer are old and ugly (yellowish)
    By joecus in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-24-2012, 08:18 PM
  3. white-yellowish little dots on the side of the pool
    By cheharrison in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2012, 06:53 PM
  4. Algaecide Overdose
    By bc9nd3h in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2006, 10:59 PM
  5. Thousands of yellowish [grey poupon] colored spots
    By jacthiele in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2006, 11:32 PM
