Thread: OTO test
    Jul 2006
    Default OTO test
    Ok super newbie here but I have been reading as much as I can. I have a 27' AG pool. I recently added Borox to correct low ph. However after adding slowly a little each day my testing for clorine is seemingly not working. It has read 5 everyday for the last week. I am getting a new test kit today but just wanted to know if OTO test were affected by Borox.
    Mark
    Rehoboth, MA
    Default Re: OTO test
    Have you been adding any chlorine over the last 5 days? If not then it probably has just been consumed and you need to add some. Has it been sunny lately but cloudy before that? The sun will cause chlorine to break down so if it was cloudy for a few days then got sunny your chlorine usage would change significantly.
    Peter
    OTO test is virtually bullet proof. That is it's main advantage. It is not the most accurate and only tests TC but if there is chlorine present it will find it!
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
