Thread: lowering alkaline
    California.
    Default Re: lowering alkaline
    Actually we don't use any pool store chemicals. I have never had to raise my PH..I use acid to lower it when it gets to the 7.8 mark..about once a month. I keep Borax on hand in case I ever need to raise the PH but for the past year it's ended up going in the laundry.
    I also haven't had to lower my Alkaline level in over a year since we put the pool in. The PH gets high, I lower it with acid, the TA stays pretty much the same until for some reason the last 2 weeks or so when it started jumping up. We have been getting ash from a wildfire in the pool since the 30th of June so maybe that is what's raising the TA? Dunno.
    It may well. Ash is known as a source of lye--sodium hydroxide, a VERY strong base.
    Morris, IL
    The wildfire situation is interesting in the change of your Ph. Is that what is causing it? I would not be suprised.
