Thread: After algae clear, when do I stop shock
    Ohio, North Canton
    Default Re: After algae clear, when do I stop shock
    Would the shock also make my CYA level read high??
    I had the CYA level checked at the local pool 2 weeks ago, and checked it with the 234 kit earlier this week and the level was 30.
    edit--Today when I looked at it, it appeared to be 50.
    I guess the take home message when shocking is not to look at the other chemistry?? Would that be a safe assumption??
    Blessings,
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
    Quote Originally Posted by TRHOD12
    Blessings,
    Well, high chloinen levels will interfere with both pH and TA tests but they should have minimal effect, if any, on CYA and calcium hardness. However, IMHO, you should not try and balance the water while the chlorine is at shock levels.
    The CYA test is somewhat subjective and it is quite possible that the pool store did not give you an accurate reading. Keep tabs on it yourself and see how it goes.
    Ohio, North Canton
    Bear,
    Thanks for the input. I'll keep an eye on it.
    Blessings,
  1. clear, but greenish -- algae or something metallic?
    By daybaron in forum Dealing with Algae & Slime
    Last Post: 07-19-2011, 08:44 PM
  2. clear water before algae bloom
    By shub_31 in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 10:24 PM
  3. Clear water but algae growing
    By mortimay in forum Dealing with Algae & Slime
    Last Post: 06-25-2011, 11:35 AM
  4. Canpressure-side robotic cleaners stop algae?
    By FRANCIS in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-14-2008, 11:29 AM
  5. Algae gone-water still not clear
    By karenkr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 11:44 AM
