I did the same thing this spring. Really wanted a pool. Didn't have the money for an inground. I researched online and found a number of good reputable A/G pools that were reasonably priced. I ended up going with a local store just so I could have the install done by them and actually look/touch one that was on display. I was able to talk to the salesman and get his take on the different models available. That in itself can get you confused. ..Aluminum...steel...resin...lots of options. The warranty is very important..look into it. It cost me a little more but at least I got to see what I was buying. Do your research on this forum and you won't regret it. There is a lot of good advice about which type of above-ground pool to buy. However, be prepared to spend about $3000 to $5000 with everything. Our Artesian 18' cost about $2800 with all the bells and whistles...pool, pump, filter...ladder etc. However, when you start to add in the costs to have the site leveled..another $600..the deck added..the toys...the test kit..Things do add up for this luxury.
As it turned out, the installation never happened through the store. I had a yard that was sloped by over 3 feet and had to have it leveled with a stone retaining wall built. (it's just softball size rocks thrown on the slope). I had an excavator do it because I didn't want the Bobcat the store installers use as it tears up your yard. They just dump the dirt on the side of the site and leave it there for you to move. We didn't want that. We did our own leveling with a borrowed laser level and installed the patio blocks ourselves. I waited and waited for the pro install guys...but ended up getting lost in the queue. If I would have had the store install it...I maybe would have been swimming in August or September! I looked around for independent installers but had a hard time finding one. I got so frustrated, we ended up putting it up ourselves with a couple friends. We did it in a day. It can be done. Saved me some money too! Unfortunately, putting up a pool usually ends up being more work than you realize. If you're realistic and are willing (AND have people to help) you can have the pool of your dreams. We actually were able to meet our existing deck up to it. It's sooo nice now..but it was a long time coming. Good luck to you!
