Results 1 to 9 of 9
Thread: Ress. vs Comm. ???
    Default Ress. vs Comm. ???
    HI All,
    I am buying a Pentair FNS plus DE filter and trying to determine flow rates. There are 2 flow rate slisted for the filter. One is under Ress and the other under Comm. Which one do I use to calculate for filter size? I am thinking Comm. My 3/4 Whisperflo will flow 70gpm so I am undecided if I should get the fns 36 which has a comm of 72gpm or the FNS 48 which flows 96gpm.
    Any ideas?
    Thanks,
    Joe
    Sugar Land, Texas
    Default Re: Ress. vs Comm. ???
    I believe you should use "Res".
    It stands for residential, as opposed to commercial.
    It is my own personal opinion that you should find out what the end-of-curve flow is for your pump and then select a filter with a rating approximately equal to that flow.
    That is an extremely conservative approach, but one that I think is wise.
    Small pump, big filter.
    Well then if that's the case I can get away with a 36sq.ft FNS plus since ress flow is 90gpm and my 3/4hp pump will only flow 70gpm. Should be a good match??
    Sugar Land, Texas
    It looks like the end-of-curve flow for a 3/4 HP WhisperFlo is about 95 gpm.
    The 36 sqft would probably be OK, but I would buy one size up. I don't know what the cost difference is.
    That's just me.
    Ft Lauderdale, Fl
    DE filter flow rates are usually double the rated square footage of the filter. A 36 sq ft will have a max flow rating of 72 gpm.
    Sean Assam
    Well for the $100 difference in price I'll up to the 48 sq.ft model. Not worth the headache or aggravation if the 36 is too small.
    Thanks!
    Joe
    Ft Lauderdale, Fl
    ALWAYS better to oversize your filter.
    Sean Assam
    If you size closer to the commercial rate instead of the residential rate you will get a much longer filter run time (time between cleanings).
    If you size closer to the commercial rate instead of the residential rate you will get a much longer filter run time (time between cleanings) because this will oversize the filter in a residential application. You also have to take into account the addtional cost for the larger filter, however.
  1. CSM Comm Error on Aqua Rite Pro
    By [email protected] in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-12-2012, 09:20 PM
