Results 1 to 10 of 16
Thread: Unable to maintain chlorine levels
    Default Re: Unable to maintain chlorine levels
    Quote Originally Posted by medstudy
    I used an over the counter drop tester (OTO). I also had my levels checked at 3 different pool stores. I have a gunite pool
    Here is a summary of the latest numbers.
    Temp:80
    Saturation Index: 0.4
    Bogus measurement
    TDS: 850
    another bogus measurement
    CYA: 50
    within the recommended range but won't stay there long if you continue to use trichlor!
    Tot. Chlorine: 0.4
    Free Chlorine: 0.4
    As Poolsean said, you have a huge chlorine demand happeining! You need chlorine until the demand is satified and the chlorine is holding. Unstabilized chlorine would be best. Bleach is unstabilized chlorine.
    pH: 7.7
    Would leave this alone now until the chlorine demand is met.
    Tot. Alkalinity: 139
    Adj. Total Alk: 124
    Tot Hardness: 314
    I wouldn't lose any sleep over these numbers.
    Since these numbers, I have added pH decreaser to normalize the pH.
    Muriatic acid is more effective and less expensive (but not as nice to work with). ..most of us on here use muriatic acid but either one is fine.
    I have also added 4 lbs of trichlor yesterday, but the current chlorine level is around zero.
    I thought about your idea that high chlorine may be bleaching out the test, but when I check the chlorine levels about 30min after the shock, it tests in the high range as you would expect ( dark yellow) (greater than 5.0 which is the limit on my tester). It is on the following day that the chlorine levels go to near zero. I wonder if I have an algae bloom somewhere in the piping of filter than I cannot see, although the water is clear. Thank you for the help.
    Your chlorine demand might be coming from some other source than algae. I am curious what kind of filter you have and what condition the filter medium is in. Also, have you added any chlorine 'enchancers' or sodium bromide algecides to the water? Both of these can create a hugh chlorine demand. Fertializer washing into the pool can create a chlorine demand. Bottom line, it doesn't matter where it comes from...you just need to keep adding unstabilized chlorine, perhaps 3 times a day, to a level of at least 12 ppm until it is met.
    I would also suggest that you get a good drop based test kit that uses the FAS-DPD titration test for chlorine (this will allow you to test high free chlorine levels accurately as well as small levels of CC), along with tests for pH, ALK, Calcium Hardness, and CYA. That way you can take control of your water. The Taylor K-2006 is a good choice but a better 'bang for your buck' is the ps234 kit sold by the administrator of this forum on the PoolSolutions website! I have one, as do many of the forum members, and it really is the best kit out there and the best value for the money!
    Jul 2006
    Thank you for all your help so far. You are right, I am posting on 2 forums. I posted them at the same time because I did not know which forum is better since I have not even been to a pool forum until I started having this problem.
    I have a Hayward sand filter. I dont know how old it is, because we just moved in the house, but my guess is that it is about five years old. It appears to be in good shape, however I do have a concern about it; I notice trace amounts of sand in the "view glass" during backwashing and I notice that my polaris is picking up very small amounts of sand. This makes me wonder if I have a sand "leak" and if so, if that contributes to my problem. My piping is fixed to the filter so it looks like it would take some sawing to get the filter apart to look in.
    I did add some algaecide to the pool a few weeks ago. It was the over the counter Aqua Chem stuff that you buy at Wal Mart. Can that do it?
    duraleigh Guest
    Medstudy,
    You seem to be bypassing the advice to put chlorine in your pool. Is there a reason for that? Is your water still clear?
    Nevertheless, I would suggest you raise your Cl in the evening to 30ppm. Then retest the next morning. If you have lost more than around 2-3ppm, you have lost it to organics in the pool and you must keep killing them.
    Bring it back up to around 25-30 each evening 'til your Cl holds overnight and then let it drift down into 4-8ppm range. That cure the issue. To do this correctly you will need a test kit that tests Cl for levels that high and accurate calculations and dosage to obtain the proper level.
    Jul 2006
    I put 8 lbs of shock today. I checked the level about 2 hours later and it was >5.0ppm so Iam hoping I am there. I will let you know tomorrow. The water continues to be clear, I think because I am being active at putting the shock in.
    Jul 2006
    This morning the chlorine level was undetectable. I went to the Wal-Mart and bought 10 one gallon jugs of the generic bleach which is 6% sodium hypochlorite. I put in 6 gallons. We will see what happens!
    That should bring you up to 18 ppm chlorine....check your chlorine levels througout the day and if they drop add more bleach. You have to keep doing this until the chlorine is holding...it might take a lot of bleach.
    Jul 2006
    Just an update. I put 6 gallons of the 6%bleach in this am at about 10am. I rechecked the levels at 3pm and they were down to zero. I only had 4 gallons left so I put it in. It sounds like I am going to have to make another dash to the Wal-Mart
