Results 1 to 10 of 10
Thread: Settle a bet about testing?
    faithfulfrank is offline ** No working email address ** faithfulfrank 0
    western New York & Leesburg, Fl.
    Default Settle a bet about testing?
    Hello all,
    My friend at work believes that all he needs is an OTO tester to check his chlorine. He says that when he puts the five drops in the yellow side, the color you first get is his Free chlorine, and after a few minutes, the color you get is your total chlorine. If there is a big difference, you have combined chlorine, and should shock.
    I told him that I did not think that was correct, and that you need a DPD testkit to accurately test FC, CC and TC. Even if he was correct, if your CC is more then .5ppm, it should be addressed, and a person could not even tell a .5ppm color change.
    Am I right? I don't understand how someone could spend over $20,000 on an inground pool, $700 on a pool light, but not spend more then $4.00 on a testkit.
    I love both my "old" PS232 and now my new PS234 testkit. Thanks Ben!
    Frank D.
    Default Re: Settle a bet about testing?
    He's wrong, but why would he believe us?
    Perhaps Waterbear can explain the underlying chemistry of OTO testing to show that only TC is revealed.
    I don't understand either why people won't spend less that $100 on a good test kit after having spent $20,000, $50,000, or $150,000 on their pool and landscaping.
    Maybe Ben and I can debate THAT in the China Shop!
    Cool Re: Settle a bet about testing?
    Carl, $100 - I just bought my ps234 and it cost me <$75 with shipping! And I got it in 10 days!! (BTW, I'm loving the kit, no learning curve [vs Taylor 2005] and it's quicker - all I have to do is figure out the 'wrist shakes' to get the water to the proper level for the tests, I've had to refill the test chambers more times this week than I've had to in the last 5 years )
    Quote Originally Posted by waste
    I know exactly what you mean. Duraleigh (Dave S.) mentioned once that his wife was using a syringe or baster or something like that. I went to Walgreen's last night and bought a medicine dropper for babies. It is a little small but should probably work great for OTO, PH and FAS-DPD. Plan on trying it out tonight.
    Northern Kentucky
    Carl, $100 - I just bought my ps234 and it cost me <$75 with shipping! .............
    Waste,
    I think CarlD was saying Ben's kit costs less than $100, and why would people not invest in a good kit that costs so little compared to the thousands of $$$ they spent on the pool??
    could be wrong, though!!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    No, Grace, that's exactly what I was saying.
    mas985's Avatar
    Pleasanton, CA
    At one time I used an OTO on my stand alone spa and I can tell you from experience that although not very accurate, you can tell if you have high CC by the color change over time. The initial color would tell you might have say 1 ppm of chlorine but have 3-5 minutes, the color would significantly darken indicating 5 ppm or more. This is not a good way to tell how much CC you have only that you have too much.
    Mark
    To all, I agree! Mas, the little kits, and even test strips (if they're good) can tell you if you're within the 'proper' range, but you need a 'real' kit to dose the pool -I think that's what you were getting at. Grace, do you think I'm crazy enough to take on a moderator?, I simply misread his post (happens all the time here, sorry to be part of the 'misunderstanding what someone posted' group , but thanks for the clarification David, the kit came with a bottle that holds enough to do all the tests, my problem is that, since it won't fit in the kit, I can't carry it with me at work (convieniently) - Looks like I'll be 'shaking out the extra water', but I love the kit . Sorry if anyone misunderstood what I tried to say - Waste
    Quote Originally Posted by faithfulfrank
    Hello all,
    While in Home Depot a couple of weeks ago, I saw that the test kit they were selling said exactly that. Is it accurate, I doubt it. Is it accurate over 5 ppm? No Way. I would even go further to say that if you compared his test to yours (assuming your testing with FAS-DPD) yours would be more accurate every time. As Carl said, he probably won't believe you any way. His loss.
    Quote Originally Posted by Carl D
    Excellent point! You'd think a $100 investment to protect this HUGE investment they made is going to break the bank. I guess it can be attributed to the fact that most people want something for nothing...
    Dave
