Thread: to drain or not to drain
    west1745 is offline Registered+ Thread Analyst west1745 0
    Dec 2005
    Default to drain or not to drain
    Hi to all:
    I have a new inground 12,000 g plaster pool with SWG. Using Ben's Kit and loving it and this forum.
    My CYA level is high - it has been at 100 for the past month. So I have had to keep the FC at 10-12 to avoid algae and to follow the chart here.
    I am wondering if I should just bite the bullet and partially drain the pool so I can lower the CYA and thus the FC. The calcium is also a little high at 400.
    FC 12
    CC 0
    TC 12
    pH 7.2
    Alk 90
    Cal 400
    CYA 100
    Temp 85
    I live in FL where it is hot and right now is our rainy season - the pool water level is a little high.
    I am not sure HOW you get the CYA level lower - is it something that dissipates in time? Or should I just drain a bit now to get it lower. It has been at that level for about a month - from a pool guy who was helping me while I was on vacation - he added too much.
    I guess why I worry is because I have a kid and 2 puppies who LOVE to go in the pool and it worries me.
    THANKS!!!!!
    Grand Prairie, TX, USA.
    Default Re: to drain or not to drain
    The simplest way to reduce your CYA is to perform a partial drain/refill. Assuming you drain 50%, you'll end up w/approx. 50 CYA. You should test your tap water for Alk and Cal. If you have hard water, you won't see much of a reduction in calcium.
    My pool water and tap water Alk is 80-90 and my tap water Cal is 100 so I was able to significantly reduce my Cal from 650 to 350 by doing a 50% drain/refill. My CYA went from 50 to 20.
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    mas985's Avatar
    Pleasanton, CA
    Most manufactures of SWGs recommend a CYA of 60-80 and CL 1-3 PPM. You might want to check your manual.
    Also, there have been many post of CYA and SWGs which you may want to read. Some, including myself, believe that higher chlorine levels are not necessary with CYA between 60-80 because of the high chlorine levels in the cell. Currently, my CYA is about 70 and chlorine is 2.0 and I have yet to have any problems. Check out this thread:
    http://www.poolforum.com/pf2/showthread.php?t=3185
    We recently had a pool party of 16 teenagers. Although the pool was cloudy that night, the next day it was clear as can be.
    Mark
  1. to drain or not to drain...
    By 2Old4This in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 07:27 PM
  2. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  3. Pool Drain or No Pool Drain (Skimmers vs. Jets)
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2006, 02:22 PM
  4. Drain...or no drain?
    By georgiapoollover in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 12:56 PM
  5. YAY!! I can see my drain!!!
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2006, 12:53 PM
