Results 1 to 10 of 12
Thread: pressure gauge/motor shutting off
    mas985's Avatar
    Pleasanton, CA
    Default Re: pressure gauge/motor shutting off
    Quote Originally Posted by Poolsean
    Brilliant minds think alike!
    Yea, I just have to work on typing faster .
    Mark
    pluck is offline ** No working email address ** pluck 0
    Jul 2006
    The hose comming out of the pool i.e. right below the skimmer basket has some small leaks.Despite the fact a leaky hose should be replaced anyway! Does anyone think replacing the leaky hose would remedy the low pressure problem???
    duraleigh Guest
    If a suction hose is leaking water, the pump is most likely off. Therefore, with the pump on, it is probably sucking air.....very possibly causing the low filter pressure.
    A pressure drop like you're describing should result in noticeable decrease of flow into the pool. If your flow back into the pool seems normal, consider the guage as a source of the fault.
    Jul 2006
    The leaky hose was replaced. The pressure gauge still reads around 2 instead of 8.
    There are 2 or 3 big air bubbles at the top of the strainer basket.
    Worst of all, the motor ran for 2 minutes then shut off.
    What should I try next???
  1. Pressure gauge bad?
    By iBrew in forum Pool Equipment & Operations
    Last Post: 05-05-2012, 08:07 AM
  2. Pressure gauge failure?
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 06-01-2011, 10:33 AM
  3. Broken Pressure Gauge
    By fog80 in forum Pool Equipment & Operations
    Last Post: 05-25-2011, 05:22 PM
  4. SP710 pressure gauge
    By cantileveredge in forum Pool Equipment & Operations
    Last Post: 09-04-2007, 09:17 PM
  5. changing out pressure gauge
    By bbluvbasket in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 12:24 PM
