Results 1 to 10 of 20
Thread: My pool is back at it again..
    Default Re: My pool is back at it again..
    I want to give you an analogy. If you have a dog that makes a mess on the rug you can spray it with deoderizer and it won't smell....for a short while! The thing is, you have not cleaned up the mess and it is still sitting on your rug and the smell is going to come back!
    The floc might clear the pool but you need to figure out why the pool is going cloudy and fix the problem. If your chlorine is not holding then you need to keep shocking and maybe increase the level you are shocking at. It sounds like you are battling algae and you have not killed it. It sounds like you are not holding a proper FC level in the pool and that is allowing algae to grow. What are your most recent set of test numbers? Post them and we will take it from there.
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Great analogy! How true!
    Numbers as of tonight
    Walmart drop kit
    CL-Really dark orange (bright yellow is 5ppm)
    Ph-7.2
    Alk-210
    Hardness-0
    Cya-15-20 ( ok, now not to sound stupid, but I hadn't checked it since my last floc, vacuum to waste-so that is why it is lower.)
    Should/ can I add more conditioner during shock session?
    Well there are my numbers-any suggestions? All help appreciated greatly!
    Won't algae make my pool green?
    The beginnings of an algae bloom are usually just cloudy water. Once the algae takes hold and there is enough of it the water will turn green. I would get the CYA up to about 40 ppm and shock the pool to about 12 ppm and KEEP IT THERE until the pool clears. The I would make sure the pool never went below 3 ppm FC. Test it every evening and add chlorine if necessary until you really get the feel for how much chlorine you need! (and do the same with the pH....test it every evening until you know exactly what it is doing in YOUR pool!)
    BTW, your alk is a bit high....don't worry too much about it now but you might want to lower it a bit once you get the pool in better shape.
    every pool is different....some people can get their chlorine to hold and have the pool clear in a few days....others take weeks. No hard and fast rules here. What you need is a big bottle of POP (pool owner patience)! Just keep up the chlorine level and keep cleaning the filter until the FC is holding and the pool is clear.
    It is working!! I can see outline around the sides! Yeah! BUT it has turned a little green again. I will keep shocking until clear view of bottom and then lower my chlorine down some and maybe add more iron out. Sounds right or should I add the iron out now? Or is the green hue a normal part of clearing up while shocking?
    Wow you guys are amazing! I had my doubts about shocking-now I totally see it works!
    I just vacuumed and scraped walls and now it is all cloudy again! I am guessing I have to keep doing that too until clear!! Still greenish though.
    in a word, yes...until you kill all the algae you need to keep it at shock level. If you do the pool will clear and your clorine demand will end.
