Re: Thanks
Chemistry
FC= 4
CC= ?
TC= ?
alk= 190
pH= 7.2
CYA= 47
temp= 85
24' round x 52" high AG pool , hayward sand filter
Talor water test kit otw here , should be tomorrow . Sta-Rite Great White - above ground p/n GW8000 orderd be here soon also .
Water after "shocking" with bleach all weekend and "brushing , and more brushing" taking the solar cover off , taking out the steps and really cleaning them , is now crystal clear tonight , no "green" spot in the sand bubbles on the bottom of pool at all , woo hooo .
After checking FC used the beach calulator to bring it up to 6 , called for 1/2 gal Ultra
at 99 cents a 3 quart bottle from Save a Lot . I really apprecite all the work that went into this site . Next time I will have time to order one of Ben's water test kits .
Gonna check later how to lower the TA .
cheers
Sprocket
