Results 1 to 10 of 26
Thread: Pool Water Chemistry (Warning: Can Get Technical)
    Default Re: Pool Water Chemistry (Warning: Can Get Technical)
    I wasn't sure where to put this interesting piece of info, so I'm putting it here in the Pool Water Chemistry thread since it is related to the chlorine/CYA relationship. This link describes a patent where a fluid is initially viscous in order to carry particulate matter and then becomes less viscous (more fluid) over time in order to deposit or settle its particulate matter. The patent uses a thickener, a hypochlorite, and cyanuric acid. Differing ratios of the CYA to chlorine determine how quickly the thickener breaks down (which changes the viscosity of the water). It's interesting that this is a patent that DEPENDS on the chlorine/CYA relationship for its proper functioning in having only disinfecting chlorine (that is, chlorine not bound to CYA and probably only hypochlorous acid) break down the thickener and having that concentration (and therefore reaction rates) be dependent on the chlorine/CYA ratio.
    Richard
    Default Ozone and Chlorine
    I didnt think this post deserved its own thread, but it is some useful info regarding ozone and chlorine. waterbear (Evan) and I worked out how ozone could oxidize chlorine since there were some reports of people using ozonators finding greater chlorine usage (loss). The following is apparently what happens:
    O3 + H2O + 2e --> O2 + 2OH- ............ Eo = +1.24V
    OCl- + 2OH- ... --> ClO2- + H2O + 2e .. Eo = -0.66V
    O3 + OCl- ...... --> O2(g) + ClO2- ........ Eo = +0.58V
    Ozone + Hypochlorite ion --> Oxygen + Chlorite ion
    ClO2- + 2OH- .. --> ClO3- + H2O + 2e .. Eo = -0.33V
    O3 + ClO2- .... --> O2(g) + ClO3- ......... Eo = +0.91V
    Ozone + Chlorite ion --> Oxygen + Chlorate ion
    With the net result being the following:
    2O3 + OCl- ... --> 2O2(g) + ClO3- ......... Eo = +1.49V
    Ozone + Hypochlorite ion --> Oxygen + Chlorate ion
    So ozone will oxidize chlorine to form chlorate. This is a very strong (likely) reaction, but the above info does not determine the rate of the reaction.
    Richard
