Re: Suggestions on Pump to Filter Connection
No the side on the filter is the standard 1 1/2" and is threaded on the inside and the pump is some weird size a little bit less than 2" and threaded on the outside. I've seen pumps at the store that have the threads on both the inside and outside, mine doesn't.
Once I have the part in that I ordered and cutting the hose I currently have to get that union nut off I will have 1 1/2" male threads on both sides.
