Results 1 to 10 of 11
Thread: Suggestions on Pump to Filter Connection
    Morris, IL
    Default Re: Suggestions on Pump to Filter Connection
    You should be able to find the connectors at home depot, but they are funny with some things they carry. The pool store would probably have them, or else I have found Ace Hardware better sometimes for some of the odder fittings. I would think that a 45 degree or 22 degree bend up by the filter would make the transition a little better too.
    cinbia12 Guest
    Hi Nicole the connection on your pump looks like the one that came with our Proline Sand filter. The end going to the pump wouldn't fit on our Hayward motor so we went back to Namco and they used a clear plastic hose that my DH tightened with clamps. We used it this way without a problem for several years.
