Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
Thread: A Cheap Pool Cooler
    Grand Prairie, TX, USA.
    Default Re: A Cheap Pool Cooler
    Quote Originally Posted by aquarium
    I suspect there's a chemical explanation occuring at the watersurface/atmosphere interface.
    As we're getting off-topic for this thread, you might review Ben's sticky topic on the subject of reducing alkalinity: http://www.poolforum.com/pf2/showthread.php?t=191
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    How does this attach to the pool? I'm in SC and our pool feels like bath water!
    duraleigh Guest
    Remove the return "eyeball" and then unscrew the eyeball base. (you'll need a "key" to unscrew the base....there are two opposing slots in the base) Then, simply screw your "device" into the standard 1.5" threads that the base screwed into.
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    And it works like a champ to lower alkalinity. Which raises the question: Will pools with 'water features' have chronic low alkalinity? Aside from the cool temps...
    I think that's exactly what happens with my pool! My PH keeps wanting to climb towards 8.0, so I add acid, which brings down TA, and then add baking soda to bring TA back up. It's like a see-saw. Right now, my TA is 100 (up from 70), but my PH is climbing back towards 8.0, so now I have to add acid. I am going to cut off the little bubbler returns in the steps and swim out to see if that helps. But I am going to run my deck jets to see if that cools the water!
    Judy
    Designated "pool girl" for 16 x 40 IG vinyl pool (installed in 2006) in S.C.
    Quote Originally Posted by docwalker
    Not if you maintain a proper pH. The reduction in alkalinity is a result of lower your pH to 6.8 or so which converts the carbonates into carbonic acid. Carbon dioxide is then released into the atmosphere by aerating.
    Have to differ from my own experiences. I have 2 deck jets, a spillover spa, and 2 waterfalls and when they are all running daily I do see a drop in the TA. It is not much....but it does occur. My pH is usually 7.4 or above (swg)
  6. #16
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    very nice, I like it.
    I have a fountain that I've messed with in attempts to lower the temp of the water but I have found it doesn't make a noticeable difference. This is probably because it's been sooo humid (90% or so) that there isn't much evaporation occuring.
  7. #17
    Jul 2006
    Upstate, SC
    Sorry to be ignorant but what do you use as a "key" to remove the base? I had no idea you could actually remove the eyeball!
  8. #18
    Quote Originally Posted by gerri
    Most well stocked pool stores sell the removal tool for about 5 dollars. It fits into the two notches in the part of the eyeball that is screwed into the pool. You remove the ring and the ball and you can see the notches.
  9. #19
    duraleigh Guest
    ScottS,
    You're right about the humidity minimizing it's effectiveness. I imagine you could still get satisfactory results if your volume is high enough. In other words, if you could divert ALL of your return water into an evaporator and get it high enough so it has some "air time", I think you would see a difference. Run time is important, too. I have to run 8-10 hours daily for the effect I want......of course, I'm running the pump anyway so it's no big deal.
  10. #20
    Lincolnton, NC
    Hey duraleigh,
    I hate to be a pain in the rear, but do you think you could possibly post some instructions and maybe some pics on the construction of your masterpiece.
  1. heat pump/cooler
    By rocky in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 10:14 PM
  2. Cooler Pool
    By mikesthang in forum Pool Equipment & Operations
    Last Post: 08-13-2011, 10:41 PM
  3. Is a Cheap Pool a Bad Idea?
    By BigDave in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 12:09 AM
  4. Cheap Cl? Check with your local pool store.
    By ChuckD in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-15-2006, 03:00 PM
  5. Water heater/cooler
    By markeast in forum Pool Equipment & Operations
    Last Post: 04-19-2006, 09:26 AM
