Results 1 to 10 of 50
Thread: A Cheap Pool Cooler
    mkelley is offline Registered+ Thread Analyst mkelley 0
    Default Re: A Cheap Pool Cooler
    That's fairly neat, Dave, and something I could use.
    Too bad I have an in-floor cleaning system (no returns except in the spa, and not much pressure there). Sigh.
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    duraleigh, I really like your idea, I have one of those floating fountains that hook into the return, but the fountain and hose get dragged all over the place when the kids are in the pool. One time, the floating fountain made its way over to the pool wall (24' above ground pool and the hose had the weight on it) and proceeded to empty the pool to the bottom of the skimmer, luckily it didn't do any damage to the pump so I am wary of it. When I use it I have added a heavier weight and it stays put, but I may try your idea out too. I am in Middle TN. and we are experiencing the high heat that you are and can't enjoy the pool when the water is so hot!!
    Dave, nice job and I bet the kids love it too. I might have to try that. Looks like a lot of fun not to mention the drop in temps. chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    Dave, Are those ends just pvc ends with holes drilled in them. What size holes did you find work best? Chris
    duraleigh Guest
    Hi, Chris,
    Yeah, 3/4" pvc end caps.....drilled 1/4" hole.
    I'm considering trying new caps with a saw cut across the top. That would give me about a 1/16" x 1/2" opening that I think will give me smaller droplets for better evaporation. Downside is that I'll lose some altitude (goes up about 20-22 feet right now) so the droplets won't be exposed to the air as long....might end up being less effective...I dunno.
    The cooler water is a remarkable improvement.
    Central Texas
    Heh,
    BMTA
    Although my version was intended to aereate the water in order to lower alkalinity:
    And it works like a champ to lower alkalinity. Which raises the question: Will pools with 'water features' have chronic low alkalinity? Aside from the cool temps...
    Grand Prairie, TX, USA.
    Quote Originally Posted by aquarium
    ...Will pools with 'water features' have chronic low alkalinity?...
    Not if you maintain a proper pH. The reduction in alkalinity is a result of lower your pH to 6.8 or so which converts the carbonates into carbonic acid. Carbon dioxide is then released into the atmosphere by aerating.
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    I think that's exactly what happens with my pool! My PH keeps wanting to climb towards 8.0, so I add acid, which brings down TA, and then add baking soda to bring TA back up. It's like a see-saw. Right now, my TA is 100 (up from 70), but my PH is climbing back towards 8.0, so now I have to add acid. I am going to cut off the little bubbler returns in the steps and swim out to see if that helps. But I am going to run my deck jets to see if that cools the water!
    Judy
    Designated "pool girl" for 16 x 40 IG vinyl pool (installed in 2006) in S.C.
    Florence, SC
    I'm in SC, and our pool temp was 90 degrees yesterday! I expect it to go higher next week too. I have 5 deck jets, so I'm going to try running those, to see if I can bring the temp below 90. Thanks for the great idea!
    You know, back in May, when we swam for the first time, we cranked up the heater and got the water to 90 degrees. It felt heavenly then; what a difference a couple of months makes!
    Judy
