Results 1 to 10 of 50
Thread: A Cheap Pool Cooler
    Default Re: A Cheap Pool Cooler
    Dave, Are those ends just pvc ends with holes drilled in them. What size holes did you find work best? Chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    duraleigh Guest
    Hi, Chris,
    Yeah, 3/4" pvc end caps.....drilled 1/4" hole.
    I'm considering trying new caps with a saw cut across the top. That would give me about a 1/16" x 1/2" opening that I think will give me smaller droplets for better evaporation. Downside is that I'll lose some altitude (goes up about 20-22 feet right now) so the droplets won't be exposed to the air as long....might end up being less effective...I dunno.
    The cooler water is a remarkable improvement.
    Central Texas
    Heh,
    BMTA
    Although my version was intended to aereate the water in order to lower alkalinity:
    And it works like a champ to lower alkalinity. Which raises the question: Will pools with 'water features' have chronic low alkalinity? Aside from the cool temps...
    Grand Prairie, TX, USA.
    Quote Originally Posted by aquarium
    ...Will pools with 'water features' have chronic low alkalinity?...
    Not if you maintain a proper pH. The reduction in alkalinity is a result of lower your pH to 6.8 or so which converts the carbonates into carbonic acid. Carbon dioxide is then released into the atmosphere by aerating.
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    Central Texas
    Quote Originally Posted by docwalker
    I've been working on lowering the alkalinity from 220ppm to (now) 70-80ppm. I've -never- lowered the pH below 7.2 during the entire process. I have had to add acid when aerating, but that was my understanding of how it works.
    But I see your larger point, that by not adding more acid, the pH -should- hold. When I hit 90-100ppm I was in a reverse situation because the pH kept bouncing back to 7.6. It looks like it's going to hold at 7.2 with the alkalinity at 70-80ppm. I suspect there's a chemical explanation occuring at the watersurface/atmosphere interface. But I'm not smart enough to explain it.
    As we're getting off-topic for this thread, you might review Ben's sticky topic on the subject of reducing alkalinity: http://www.poolforum.com/pf2/showthread.php?t=191
    --Rx
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    How does this attach to the pool? I'm in SC and our pool feels like bath water!
    Have to differ from my own experiences. I have 2 deck jets, a spillover spa, and 2 waterfalls and when they are all running daily I do see a drop in the TA. It is not much....but it does occur. My pH is usually 7.4 or above (swg)
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    very nice, I like it.
    I have a fountain that I've messed with in attempts to lower the temp of the water but I have found it doesn't make a noticeable difference. This is probably because it's been sooo humid (90% or so) that there isn't much evaporation occuring.
    Jul 2006
    Upstate, SC
    Sorry to be ignorant but what do you use as a "key" to remove the base? I had no idea you could actually remove the eyeball!
