Results 1 to 10 of 50
Thread: A Cheap Pool Cooler
    duraleigh Guest
    Default Re: A Cheap Pool Cooler
    The cost/benefit ratio of this $6.00 device is the best money I've spent on my pool (other than Ben's kit)
    Temp @ 4:00pm today...96 degrees -dewpoint 68 (that's pretty humid)
    water temp is a refreshing 84 degrees. Last year, I couldn't stay much below 90 during these temps
    mbar's Avatar
    Ashland, PA
    and I put solar panels in to keep my pool above 80! It's a crazy world!!! Great invention!
    Northeast PA
    Jul 2006
    I would be interested in a part list for your invention. Most importantly, the parts needed to connect to the output jet.
    Tom
    duraleigh Guest
    Tom,
    Once you remove the eyeball base with the key (see above), what you have in the wall is 1.5" pvc female threads. (Not on all pools but most IG's)
    Simply screw in a 1.5" male thread connected to a 90 and bring the 1.5" pipe up about 6" under the surface. "T" that pipe and reduce down to 3/4" on both sides of the "T".
    Then, with T's and a 90 on each end, put however many vertical 3/4" sprayers you want, along that 3/4" pipe. drill a hole in some end caps (I used 1/4") and glue them on the top of the verticals. You can make out the outline of it in one of the pics
    Whole thing took me a couple of hours of thinking about it and probably an hour or so glueing it together. You can get as creative as you want with the number of sprayers, angles of the sprayer, hole sizes, etc. The idea is to get a lot of water high into the air and let the evaporative process work.
    While in the pool, I caught the falling water in an insulated cup with the pool temp guage in the cup. Temp in the cup was 78 degrees on a 93 degree day. Not bad for 6 bucks.
    Where do you get the threaded fittings? From a home improvement center (Home Depot) or a pool store (Leslies)?
    Central Texas
    Quote Originally Posted by hulla
    Home Depot, in the plumbing section. Most pool returns are 1.5" but you might want to remove the eyeball fitting first to be sure.
    duraleigh Guest
    Hulla,
    They are standard pvc fittings readily available at any HD/Lowes....there's nothing extraordinary about any of the parts. The bushings that reduce the 1.5 inch pipe down to 3/4" might be a little tough but I picked them up at Lowes....the first place I stopped.
    Jul 2006
    Quote Originally Posted by duraleigh
    Tom,
    Thanks Dave, I think I will give this a try this weekend. I am in the Dallas/Ft. Worth area and we are seeing temps in the 104 range. My pool is sitting at 92 right now, would love to get it back to 86 or so.
    Tom
    Lutherville MD
    This is a great idea, but my inground pool is old and has no eyeball fitting. The returns appear to be simple non-threaded openings in the side of the pool. Can I remove the existing non-threaded pipe that seems to be in the returns, or do I need to do something to get a threaded pipe in place? Any ideas would be helpful.
    duraleigh Guest
    Handy,
    If it's pvc pipe, try a reducer bushing. It will fit snugly into the return pipe probably from friction alone.
    You'll have to glue/screw your assembly together with the bushing on the end and then tap the bushing into the existing return pipe. Although that's a "made up" solution, I'll bet it will work.
  1. heat pump/cooler
    By rocky in forum Pool Equipment & Operations
    Last Post: 07-11-2012, 10:14 PM
  2. Cooler Pool
    By mikesthang in forum Pool Equipment & Operations
    Last Post: 08-13-2011, 10:41 PM
  3. Is a Cheap Pool a Bad Idea?
    By BigDave in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 12:09 AM
  4. Cheap Cl? Check with your local pool store.
    By ChuckD in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-15-2006, 03:00 PM
  5. Water heater/cooler
    By markeast in forum Pool Equipment & Operations
    Last Post: 04-19-2006, 09:26 AM
