Results 1 to 10 of 50
Thread: A Cheap Pool Cooler
    duraleigh Guest
    Default Re: A Cheap Pool Cooler
    Hi, Vol,
    I do not leave mine on. Since a circulate the water approx 8-10 hours daily, I point the evaporator into the air on days I feel I need to cool the pool. On days I don't feel the need, mine simply pivots downward into the water and I'm back to normal operation. Pretty convenient.
    As an update, Raleigh had two consecutive 96+ days last week and my pool's highest temp was 84....running daytime only for 10 hours. I know you can't get something for nothing but this comes pretty darn close for me. Ran it pointed up all day yesterday 'til dark and water this AM was 79 degrees! It'll be pointed down all day today.
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    BRRRRR! I went out to do my weekly testing this morning, and my water is at 75 degrees! I am going to remove them and screw the eyeballs back in. Once my water gets back above 85, I'll put them back on. The kids love them as they play in the spray.
    One interesting thing Dave, my skimmer seemed to work better with these on both of my returns. I was afraid it would be rendered useless since the water wasn't circulating as normal. I think I will adjust the eyeballs so the water kind of dies in front of the skimmer. Before, I would watch the debris float by the skimmer. Going to have to put the fur panties on underneath the bathing suit to swim today, but it beats the 91+ I had prior to adding the coolers, as my water would probably be 100 now, and you feel like you are marinating in a crock pot instead of swimming.
    duraleigh Guest
    Vol,
    More info than we needed!
    Broken Arrow OK
    I just finished plumbing in my new pump, I think I have almost everything needed already. I'm gonna get on it right now. We've had daytime highs of 92-106 for 23 days straight.
    27K IG Gunite
    1.5 hp pentair whisperflo
    Hayward Micron DE filter
    duraleigh Guest
    The T is threaded so I can slightly unscrew it 'til the "jets" point downward.
    You could certainly use the line from the booster. Wont hurt the pump. Probably shoot the water VERY high making up for the low volume you would expose to the evaporative process. I'm not sure of the results but mine was/is an experiment, also.
    Ft Lauderdale, Fl
    I would suggest that rather than a cap on one end, glue a ball valve so that you can control the amount of spray out of the "jets". This way, if you didn't want a high spray (especially on a windy day where you will lose water), you can open the ball valve to adjust the spray your desired height. This will also allow you to adjust the heat loss so you're not swimming in cold water in the middle of summer.
    Sean Assam
    I took my pool coolers off last week when my water hit 75, and this morning it is back to about 84. I'm sure it will get to 86 or so this afternoon. Time to break them out again!
