Results 1 to 9 of 9
Thread: laundry detergent in my pool....Whoops
    Jul 2006
    Angry laundry detergent in my pool....Whoops
    I asked my wife to pickup 10 pounds of baking soda for our pool and told her to check the laundry detergent area for big bags or boxes. Without reading the boxes she brought I proceeded to dump 10 pounds of Arm & Hammer detergent in our 24 feet above ground pool . What is that going to be the long-term negative effects of this? The PH is off the scale at 8.2+ and the aqua chem. Site says that the total alkalinity is to high also and that the calcium hardness is to low.
    Default Re: laundry detergent in my pool....Whoops
    Unca, I don't really know, but can you drain and refill ? If not mahaps someone else here knows of a solution
    Jul 2006
    please help me someone . there must be someone with experience with a problem like this through accident or via pranksters. I put some ph down in tonight but it just looked a bit foamier (if thats a word). I will retest in the morning and also take a sample to my pool shop. Please let me know if you have any suggestions.
    Thanks,
    Uncle Jabba
    Besides the detergents you have added a lot of sodium carbonate (pH increaser) to the pool with the addition of the laundry detergent. Your TA and pH will be the easy fix. The foaming from the detergent won't be. I would recommend draining the water and refilling. You might want to try a defoamer (simethicone) but I don't know how well that will work or what the long range effects will be.
    Drain it and refill. That's what I would do.
    duraleigh Guest
    Drain it.
  1. HELP Laundry detergent in pool
    By cactusjak in forum Pool Chemicals & Pool Water Problems
    Last Post: 12-06-2010, 11:54 PM
