Thread: New Pool Owner Water Test Results
    Jul 2006
    Altamont,NY
    Default New Pool Owner Water Test Results
    TC-1.3
    PH-6.2
    Hardness-30ppm
    Alkalinity-40ppm
    Copper-.15
    What do I use to raise the PH,Harness and Alkalinity?
    What do I use to lower the Copper?
    In what order do I do them in?
    Rocket City, AL, USA.
    Default Re: New Pool Owner Water Test Results
    What size and type of pool do you have? This is pertinent information needed to give you advice.
    Jul 2006
    Altamont,NY
    My pool is 18'X33' with 52" wall 18000 gal.
    mbar's Avatar
    Ashland, PA
    You will need to get your alk and ph up asap. According to the bleach calc, you will need 18 lbs of baking soda to get your alk up to 100. It will also raise your ph, but if you need to raise it more after the baking soda, then use borax. You will find the bleach calc here:
    http://home.earthlink.net/%7Emwsmith...achCalc262.exe
    You will need to put a sequesetering agent in the water to control the copper. You will need to find out if there is any stabalizer (cya) in the water to know where your chlorine level should be. You don't need calcium in a vinyl liner pool. So your hardness level of 30 is ok. Read a lot on the pool forum, and go to pool solutions to read about water chemistry. Welcome to the forum!
    Northeast PA
    Jul 2006
    Altamont,NY
    About rasing the Alk do you mean regular baking soda?
    Where would I get the baking soda and Borax?
    mbar's Avatar
    Ashland, PA
    Yes, regular baking soda that you can buy at the grocery store, you can also buy borax in the grocery store by the clothes washing aisle. I recommend you go to the "Pool Solutions" web site - there is a whole list of swimming pool tips to read through. This site is good because it explains what you can buy from a grocery store that is the same that is sold at a pool store for much cheaper.
    Northeast PA
