Results 1 to 10 of 15
Thread: goggles and masks...
    Upstate, NY (Dutchess County)
    Default Re: goggles and masks...
    I bought an Aqua Sphere Seal Kids for my son tonight (expensive for kid's masks at $20). Tomorrow it'll be returned. The Seal does not seal very well across the bridge of his nose. THe straps have to be painfully tight to eliminate any visible gaps.
    I do like the design and am considering the purchase of the adult version for myself. Perhaps it's because my Son's got a flatter bridge or he's too young (5yrs old).
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Dec 2005
    TYR "Youth" works very well for kids and are no more than $10.
    I got some speedo ones. There @ academy for less then 10.00.
    I tried Speedo, TYR and NIKE (Nike makes goggles?)
    But when I tried alll of them the Speedos felt so nice and seem I can see more with them.
    Since I love to go all the way to the bottom of our pool (8 feet), it just makes it more fun.
    What really honetly helps me out a lot also is the speedo nose plug. I can hold my breath underwater allot longer now. At least by 30%.
    When you guys mean Cheapo goggles, what brand are you speaking of?
    Or do you mean just in price??
    My son has a set of DOLPHINO goggles they leak a little and fog really bad after about 3 dips in and out from under the water. My speedos are anti-fog and as of yet leaks what-so-ever.
    Overall I am happy w/ my $9.00 speedo goggle purchase. It does make a world of difference when going down under the water.
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Ontario.
    To buy swimming goggles I have to try a lot of different ones on that fit my face correctly. I find it's more about the shape and pressure points to get a pair that seals and is comfortable, and there isn't much correlation with price. Masks aren't that big a problem but for goggles I would hit a store with a good selection.
    Jul 2006
    Nova Scotia CANADA
    I prefer masks over goggles; I have slanty eyes ( very asian looking almond shaped) & most goggles just don't fit correctly ; or rather the cheepo ones don't, so I use cheepo masks.
    @ Simmons 99 ( or other vision correction people)
    If you don't mind spending some cash on goggles or masks, Talk to your eye wear professionals.
    Prescription masks & goggles are available... I don't know if many health insurance compnaies would cover this prescription but it is worth investigating.
    I had a fabulous pair of prescription goggles many years ago when I was on the swim team.. They were awesome! eventually I changed prescriptions though & was no longer on a swim team so I didn't bother buying new ones; but they were great!
    Tip for anti-fogging
    SPIT...
    most divers know this trick;
    simply spit into your mask or goggles.
    I don't know why this works ( perhaps chemgeek could explain the scientific principle behind it), but it does work really well...
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    Try TJMaxx or Marshalls if you have one in your area. I have found speedo goggles there for around $5. They seem to work well. I found some decent ones on clearance at walmart for around $5 too that I am using now, but I can't remember the brand name right off hand. I have to hide them from my kids because they destroy them
    Jul 2006
    Pearland, TX (Houston suburb)
    LeeJP,
    Your thread shows being from upstate NY. I am sure you are close to lakes and what not up there and therefore should be close to some Dive shops (SCUBA). Most of the threads have discussed goggles over masks. If masks are the way you want to go, I would suggest visiting a dive shop. Or, here are some tips to fit yourself with a good sealing mask:
    Find the mask that you like and looks like it will fit your face well. Without using the strap, place the mask up against your face (make sure to move hair out of way). Inhale through your nose pulling the mask in towards your face then hold your breath. If you feel the mask pulling away, then you have air leaking in ( Not a good fit mask). Try this on several masks until you find the right one. You will know because that mask won't budge. I have a mask that I have had for the past 8 years for SCUBA diving. It still seals just as well since the first day I bought it. Good luck.
    Sanford, FL
    Quote Originally Posted by divnkd101 View Post
    LeeJP,
    ... be close to some Dive shops (SCUBA). Most of the threads have discussed goggles over masks. If masks are the way you want to go, I would suggest visiting a dive shop.
    Totally agree - DH went to the dive shop down here and got a mask that fits HIM (no one else can wear it) really well - and it wasn't the most expensive - it was actually one of the lower priced ones. He had to try on about 25 until he got one that didn't leak air.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
