Results 1 to 10 of 32
Thread: rising ph levels
    ohio.
    Smile Re: rising ph levels
    The pool is vinyl lined and I thought my alk levels were okay for my pool. I stopped aerating after I got the alk down and there really hasn't been anyone in the pool. I guess you just have to keep adding acid to keep the ph down. Thanks for the help.
    ohio.
    Default Re: rising ph levels
    What does the check mark after my post mean? Just curious.
    SoCalBoo is offline Registered+ Thread Analyst SoCalBoo 0
    San Diego
    wolfcue - you don't have an swg by chance, do you?
    Quote Originally Posted by wolfcue
    It means you are subscribed to the thread and you can check settings in your control panel to get email notifications of new posts in the thread.
    La Jolla, CA
    Rising pH
    Are you using the all bleach method? If you are, that may be why it is climbing.
    Anything that you add to the pool, can change the pH depending on the pH of what you are adding.
    Bleach, sodium hypochlorite, has a pH of around 10 or 11, very alkalotic, so the more you add, the higher your pH will go.
    I have found that in my pool which is open all year round, I ONLY ADD 2 chemicals!!!!!!!!
    Bleach and Acid.
    Bleach for my source of chlorine and acid once in a while to bring the pH down.
    That is it. Once your pool is "tuned" it can be that simple.
    Quote Originally Posted by azimmer1
    Rising pH
    Though you are correct that bleach is alkaline (the 12% stuff from pool stores has an even higher pH of 13), chlorine usage is an acidic process so the net effect of chlorine addition and usage is a very small rise in pH due to the extra base that is added to (or kept in) the chlorine bleach (to keep it more stable). When chlorine is broken down by sunlight (UV) or consumed by ammonia to breakpoint or oxidizing organics, the pH goes down by almost the same amount as it goes up when you added it.
    [EDIT]
    By "chlorine usage" I mean when chlorine gets "used up", not your usage (addition) of chlorine. Sorry for the confusion.
    [END-EDIT]
    After reading several posts about pH rise, I am coming to the conclusion that it is most often due to outgassing of CO2 which raises pH (and when you add acid to compensate, the alkalinity is lowered and you get back to the original pH -- so the net change of CO2 outgassing plus adding acid is that the alkalinity drops). Aeration of pool water is the most common cause for this. It looks like many people live with a lower alkalinity of around 80 in such environments. Also, keeping your pH closer to 7.5 helps since lower pH accelerates the outgassing process.
    Richard
    Last edited by chem geek; 07-19-2006 at 09:28 PM. Reason: Clarified "chlorine usage"
    ohio.
    Thanks to everyone for the help.
    La Jolla, CA
    chem geek/Richard
    By what mechanism is adding bleach an acidic process. I am not doubting you, just curious as to why
    Andy
