Re: rising ph levels
chem geek
If "aquarium" is correct and this extra pH rise is due to your outgassing carbon dioxide from your pool to the air,
Not really what I said, and I'm wrong anyway.
I keep what is called a high-tech planted aquarium. I inject CO2 from a pressurized cylinder into the aquarium water so the plants will grow well. I've been down the road of -very- high tech automation and don't want to go there again with the pool. But I am familiar with the alkalinity-CO2 relationship.
In Austin, from where we recently moved, the water comes out of the tap at 10 pH and about 80ppm alkalinity. They intentionally drive all CO2 out of the water to -raise- pH and -lower- acidity so the water will be gentle on the pipes. Let that same water just sit out for a few hours and it will take in CO2 from the atmosphere and settle in at a pH of about 7.6.
I should have known that if I lowered my pool water to 80ppm alkalinity that it should behave similarly, and so it has. The pH has now risen to 7.6 and so far is holding there. But it's too soon to tell if that will hold. It seems to move in increments.
I wasn't suggesting that outgassing is caused by pH, I'm suggesting that the alkalinity of the water will -set- the pH due to the natural interaction between the water and air as CO2 in both reaches a balance point.
Tom
Tom Wood
15K IG Plaster, Sand Filter, Polaris 180
