Thread: Oops! my kid caddyshacked the pool.
    jenpen400 Guest
    Default Oops! my kid caddyshacked the pool.
    Yup I've got poop! I dumped my last too jugs of bleach in and numbers are as follows FC 8.5 CC 0 PH 7.8 CYA 50. The accident was contained in a swim diaper but I'm sure some escaped. What do I have to do to make the pool safe to swim in again? DD was having so much fun learning to swim without floaties and going under water I didn't want to make a big deal over it. Thanks again.
    jennifer
    IL.
    Default Re: Oops! my kid caddyshacked the pool.
    Are you sure she wasn't just hiding a baby ruth?
    http://www.poolforum.com/pf2/showthr...highlight=poop
    As there was no visible 'debris' and it's been 6 hrs, with elevated cl, I'd have to say that you're ok for an evening swim, if you have any doubts (or she's been sick) you may want to hold off til morning and let the pump keep running tonight.
    Morris, IL
    Lake Michigan always has high levels of fecal matter and Ecoli bacteria in it, and the Chicagoans are all ok.
    jenpen400 Guest
    Thanks folks. We are hitting 100 again today. This would not be a good time to take the pool out of service DD says it's to hot to play on her new swingset. Took the clorine up to 10. That should nuke the poop!
  1. Newbie here! Already filled my intex 15x36 pool with water (Oops!)
    By joolz1226 in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-03-2012, 08:40 PM
  2. oops I caused a perfectly clear pool to be cloudy
    By Cords in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2011, 10:08 AM
  3. Oops!!
    By Sumo1 in forum Pool Equipment & Operations
    Last Post: 08-21-2007, 03:48 PM
  4. Big oops.....non-pool antifreeze in water :(
    By chrisexv6 in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-29-2006, 09:32 AM
  5. oops.... I used a floc!
    By no1ford in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-22-2006, 10:12 PM
