Thread: pH color deciphering
    Default Re: pH color deciphering
    What is your chlorine level? Sounds like you are getting chlorine interferance in your rainbow kit. The phenol red in the Taylor kit has a chlorine neutralizer included in the reagent and will work with chlorine levels up to about 15 ppm. the rainbow phenol red does not. What is happening is the phenol red in the rainbow kit is being converted to chlorophenol red which tests the pH range of 4.6 to 6.8 with the same color changes as phenol red has from 6.8 to 8.2 so the purple color you are seeing means the pH is above 6.8! Yellow-orange color should put your pH in the neighborhood of 7.2-7.4. Orange is about 7.4-7.5. Hope this helps.
    Question Re: pH color deciphering
    Evan, thanks for the info! Would a couple of drops of thiosufate correct the Rainbow kit and vice versa, could the Rainbow kit be used to test REALLY LOW pH if a few drops of bleach were added? (every year we lose a few copper heat exchangers due to low pH/ alk and I'd like to know how bad the water is so I can properly adjust it - as for why this happens, the owners use only tri-chlor pucks and [the antithesis of CarlD's advice] 'spend 2 - 5 minutes a year to buy a new heat exchanger' - no joke, there are some we replace every year and tell them how to avoid it.)
    Quote Originally Posted by waste
    a drop or 2 of chlorine neutralizer should work to remove some interferance...don't really know abut the other way round. You would really need a comparator for the chlorophenol red to get an accurate reading...some soil testing kits have indicators in lower pH ranges...might be an option to explore.
    Some people just don't want to deal with their pools. If they won't take the time to take care of their water I say make all the money you can off of them with the new heat exchangers every year!
    Rock Tavern, NY
    [What is your chlorine level? Sounds like you are getting chlorine interferance in your rainbow kit. The phenol red in the Taylor kit has a chlorine neutralizer included in the reagent and will work with chlorine levels up to about 15 ppm. the rainbow phenol red does not. What is happening is the phenol red in the rainbow kit is being converted to chlorophenol red which tests the pH range of 4.6 to 6.8 with the same color changes as phenol red has from 6.8 to 8.2 so the purple color you are seeing means the pH is above 6.8! Yellow-orange color should put your pH in the neighborhood of 7.2-7.4. Orange is about 7.4-7.5. Hope this helps.]
    Here are 2 sets of numbers from yesterday:
    3 pm:
    FC=2.5
    CC=0
    TC=2.5
    pH=7.5 (assumption)
    Alk=75
    CYA= Assumed less than 30
    At 8 pm after 100 degree heat, 3 little kids and addition of 1.46 galls and 3 qts bleach, 1 lb borax:
    FC=8
    CC=.5
    TC=8.5
    pH=7.5 (assumption)
    Alk=75
    I haven't tested it yet today (pool's at my mom's house)
    18x42 Spartan Roman End Vinyl Inground (1981)
    1HP Hayward Superpump -- Hayward Perflex EC-65 DE Filter
