Closed Thread
Thread: Deep Heat Lines for spa?
    OC, CA
    Default Deep Heat Lines for spa?
    Can someone tell me what the deep heat lines are for in a spa? My plumber is giving me the option. From what I understand it is a 3 way valve that diverts heated water from the heater. But how and why? This is for a gunite spa only with no pool.
    THANKS!!!
    Default Re: Deep Heat Lines for spa?
    The only thing I can think of is that water is being diverted to the bottom of the spa instead of the walls of the spa. Hope this helps
    OC, CA
    Does this help much for an oversized spa? Sounds like it would be minimal?
Closed Thread
