Results 1 to 10 of 11
Thread: Dichlor/trichlor????
    lynnybug55 is offline ** No working email address ** lynnybug55 0
    Upstate South Carolina
    Question Dichlor/trichlor????
    I have been a "convert" for a little over a year now, and frequently scan the forum for new info or reminders. I have two questions for which I can't find an answer. First, what in the world do you do with all the empty bleach jugs? We live in a rural area and do not have trash/recycle pick up. Second question: where can you buy a dichlor tablet? I'm assuming from reading various posts that this does not have stabalizer. All I can find are "3-in-one". I have finally got my stabalizer level down to about 45 from over 180 in April 2005 when I switched to bleach. Thanks for all the good information!
    Poughquag, New York, USA.
    Default Re: Dichlor/trichlor????
    DiChlor does have stablizer. I have only seen it sold in granular powder form. It is normally put in the pool or spa by broadcasting, the granular form allows it to dissolve quickly.
    Then what is the difference and why is Dichlor better than trichlor? What kind of tablet do you use to maintain the chlorine level if using bleach?
    Indiana.
    Quote Originally Posted by lynnybug55
    The bleach IS what maintains the chlorine. No tablets required.
    Unhappy Re: Dichlor/trichlor????
    I think I'm confused. I thought I read somewhere on the forum about using bleach and some kind of chlorinator/feeder/floater. Did I dream that, or am I just misinterpreting what I read?
    Northern Kentucky
    The floater is one method used to deliver CYA, or stabilizer to the pool. You already have a good CYA level, so you needn't bother with di/tri-chlor, or with the auxillary floater. Just add bleach to keep your FC levels in range.
    The CYA is what keeps the sun from degrading your chlorine.
    Regarding the empty jugs, what do you do with the rest of your trash? I would rinse them out and dispose of them the same way.
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    La Jolla, CA
    Most floater are for TRICHLOR tablets. Yes trichlor as well as dichlor has CYA. So if your pools CYA, stabilizer level is OK. don't use it.
    There really is no advantage of trichlor vs dichlor. Both are stabilized chlorines
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    Yup.
    Di-chlor is stabilized chlorine, typically in granular form. It's easy to broadcast, dissolves fairly readily, adds chlorine and cyanuric acid (cya) to the pool.
    Tri-chlor is stabilized chlorine, generally in tablets, or pucks. Dissolves more slowly so it's suitable for floater use. It adds chlorine and cyanuric acid to the pool.
    Bleach, or sodium hypochlorite, is non-stabilized chlorine. Laundry variety is typically 5.25 to 6 percent strength (pool store stuff may be 12% at full strength, but it drops off easily to 8-10% over time), and adds chlorine to your pool, nothing else.
    Smile Re: Dichlor/trichlor????
    Thank you; I understand now! One more question: Can someone give me a link to Ben's calculator I've seen mentioned here?
