Results 1 to 4 of 4
Thread: Green Water
    NY, USA.
    Question Green Water
    Help~~~ Yesterday my pool was crystal clear & when I came home today it is turning green. I use the Nature 2 Sanitizer, so I only shock once a month. I put Algaecide in once a week & non chlorine shock 3 weeks out of the month. Could the heat have something to do with it?? The water temp is now 88 degrees. What should I do???
    Indiana.
    Default Re: Green Water
    Quote Originally Posted by Sunshine427
    To be blunt, you can't use Nature 2's imaginary chlorine levels and follow the program here. The Nature 2 puts copper and silver in your water. If your algaecide has copper in it, then you are double dosing your water on copper. Green hair problems by any chance?
    What should you do? Get rid of the Nature 2, switch to polyquat algaecide, add a metal sequestrant to get the metal out of the way, and start keeping your chlorine at a safe level.
    Try testing the pool water for pH, FC, CC, CYA, TA.
    Sanford, FL
    You really need to post your levels - also take a sample to the pool store to get tested for copper level. You may need a metal sequestering agent prior to shocking your pool with bleach.
    We cannot tell you want you need to add without your test results.
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
