Results 1 to 4 of 4
Thread: Ph Not Increasing
    Default Ph Not Increasing
    I have a 16X32 kidney vinyl liner, i cant ge the PH up in the past to days i have 10lbs of PH up no change. Any Ideas??
    total alk = 80
    total chlorine = 3
    free chlorine = 1
    ph= 6.2*
    Morris, IL
    Default Re: Ph Not Increasing
    Try Borax, maybe the ph up is no good...?
    duraleigh Guest
    How are you testing pH that low? If it's accurate, you are in immediate need of lots of borax and chlorine as well. Describe how you test before adding anything.
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Turn your eyeball jets straight up to aerate the water, that may help some. It certainly raises my Ph
