Can you pour into a skimmer if you don't have a clorinator? Is it safe for a vinyl liner?
I have a vinyl lined pool. I also add my bleach to the skimmer, in fact I add all the chemicals EXCEPT for muriatic acid to the skimmer.Originally Posted by jmjbj_h
~Dr. Spike
Pool: IG vinyl, heated, fully enclosed (dome)
Shape: Grecian (rectangular)
Size: 20'W x 40'L
Depth: 4' / 8'
Filter: Sand w/DE added
Other: 6' Diving Board
Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
If you have an automatic chlorinator with no tabs in it is it OK to add the Bleach directly into the skimmer?
Sure, no problem...just add to the skimmer.
I believe that I read somewhere on this board that you should never pour bleach through your skimmer if you have an auto-chlorinator that has been used with pucks.Originally Posted by JimSentry
Could be wrong though...![]()
~Grace
Avid reader of this forum
but alas, no pool... yet!
I usually pour it in the pool in front of the return jet.
Peter
You should never pour bleach through the skimmer with a auto chlorinator in line. The result could be very dangerious. I just pour slowly in front of the return jet. Pour slow enough that you dont have slugs forming or get splashed on (i have runied shirts by splash).
What's a Slug?
Thanks for all those replies. I think I am going to try it. I still a little nervous. How does the bleach compare to shock? Does 1 galloon of bleach the same a 1lb of shock? or does it compare differently? Thanks again to all who responded. This is all new to me.
