Thread: Help with green water
Threaded View
  1. #2
    Ohio, North Canton
    Default Re: Help with green water
    Jerry,
    I'm ,by no means, an expert on this. But I did sleep in a holiday in express last night . (Sorry, wanted to start with a little humor)
    I just this past weekend went thru this same thing.
    From what I've read and what I've experienced you will need to keep your shock FC in the 15-20ppm range till the algae clears. I know this is dependant on the amount of CYA that is in the pool, but it seems like you're just not maintaining enough FC to kill the algae. I didn't see what your CYA level was. What is it?? That will tell you where your shock level FC should be at.
    In my recent episode with algae I was testing three times a day, and was loosing ALOT of FC thru out the shock phase. I'm talking 4-8ppm in a 5-6 hour period. So yes, to answer your question, your pool could have been using up the entire bleach that you added.
    You've got to get the FC high, but it seems, most importantly you need to maintain this high level UNTIL THE TC HOLD OVER NIGHT. This is important. I say TC here and not FC, because from what I understand, after you shock to the appropriate level there should not be any CC.
    With my pool, the pool cleared up in about 1 1/2 days, but my chemistry was still telling me that the FC was fighting algae. I was still loosing 2-3ppm over a 5 hour period. This went on for another 24hrs. I maintained the shock level, and over night the TC held. This told me the algae was all gone.
    Be patient, be persistant. Keep the shock levels up, do not let them drop below 15, brush and vacuum (I did twice a day). It should clear up.
    I hope this helps, and I'm sure others more in the know will chime in and help you out. This is by no means a "gospel way to cleaning algae", just one newbee's recent experience with algae and my limited knowledge on the subject.
    BLessings,
    Ted (TRHOD) North Canton, Ohio
    1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
    Acquired pool June 2006 Been BBBing ever since
