Re: words of encouragment!
Can I cause damage to my liner from keeping my FC levels at 15 ? In another post on this sight it said for vinyl liners to only get my FC levels to 10. I don't want to cause even more problems. My kids hate me already, this has been the hottest week here in Illinois mid 90's all week and we can't use our pool!
Thanks to everyone for all the help.
Leslie
Tell your kids that they are lucky, I live in Illinois, and I just popped my left eye, I cannot use the pool for who knows how long. They will be able to use it soon.
You should be able to run the cl level up to 15ppm (on a short term basis, such as your baquacil conversion) with no long-lasting problems. I would not recommend doing it on a long term basis, but for the several days of a baquacil conversion, many (if not most) of us have had our cl levels in the 10-15ppm range.
My liner was virtually new when I did my conversion (shortly after I installed my pool). This is my 3rd summer with chlorine, and the liner is still a nice, dark blue. I normally keep my FC level at the 3-5ppm range.
The only place that is faded is where I dumped in too much cal hypo when I was doing the conversion, and it sat on the pool bottom for about a day. Oops! No harm done, but it's bleached in that area.
As far as the 15 ppm level, as soon as you bring the chlorine level up to 15 ppm, it will start to get consumed and will drop soon so it isn't until you're done that you will actually hold at 15 ppm therefore the liner effects should be minimal. It will improve the conversion time though so keep it up!
Peter
Hi All,
The only test kit I can find only measures CL to 3. What is the process to check levels up to 10-15.
I know this involves dilutingmy pool water with distilled water and multipling your numbers, however I do not know how much distilled water or what I multiply my numbers by.
Leslie
Take a small sample of pool water (shot glass or some other unit) and add the same amount (or more) of distilled water and multiply by the following:
for 1 unit distilled water, multiply result x 2
for 2 units distilled water, multiply result x 3
for 3 units distilled water, multiply result x 4
for 4 units distilled water, multiply result x 5
To get a reading for 15ppm if your scale only goes to 3ppm you will need four units of distilled water added to one unit of pool water.
Peter
One part pool water to three parts distilled water, then mix, take a sample from this in your tester, add the drops, multiply the result by four. This would get you up to 12 if I am not mistaken. You could do one part pool water to four parts distilled and multiply by five to get to 15.
Keep in mind the dilution method is highly innacurate....you would do well to get Ben's kit...no more guesswork.
