Thread: Best Vacuum for Sand Pickup
    Default Best Vacuum for Sand Pickup
    Have the Polaris 360 w/extra fine bag, but was curious if pressure cleaning is the best way to pick up beach sand. Most of my dirt is sand since I live 2 blocks from the beach, but my backyard is all deck lumber, so the sand is coming from the air. I find that I need to take apart the cleaner about 2-3 times per season, because the wheels stop moving (sand is jamping the gears). Should I switch to suction cleaner or what is the best automatic cleaner(s) for sand pickup? Txs Gary (Seaside Park, NJ)
    mas985's Avatar
    Pleasanton, CA
    Default Re: Best Vacuum for Sand Pickup
    Usually, suction side cleaners work best for fine dirt and sand since it uses your filter to remove the dirt. However, they are less attractive for pools with lots of leaves although separate leaf baskets can be used.
    Robotics usually have pretty good filters so these would work as well and don't require a change of plumbing.
    Mark
    Default Good Quality Suction Side Cleaner for Sand Pickup???
    Could anybody recommend a good quality suction side cleaner for sand pickup?
    I saw the G4 or Polaris 150. At least from my research on how these suction side cleaners work.
    I will be getting the 150 when my pool is complete.
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    mas985's Avatar
    Pleasanton, CA
    I have the pool cleaner which seems to work pretty well and needs less suction than some of the others. It climbs walls pretty well too.
    www.thepoolcleaner.com
    Mark
