Thread: newbie QUESTION
    rnjng Guest
    Default newbie QUESTION
    We haven't been able to run our pump in the past 2 weeks. the first week the water was pretty clear, better than I expected. and the sencond week, it started to look green, as I expected. And kknow, within the past 2 days the water is clear, no problem seeing the bottom, but there are some green, well look like green patches of fuzz( i guess, not sure how to explain) on the bottom of the pool, what is it???
    geordie is offline ** No working email address ** geordie 0
    Default Re: newbie QUESTION
    Green fuzz in uncirculated water is algae.
    rnjng Guest
    YIKES! what should I do??? can I vac. 1st, or should I shock tills it dead and then vac.?
    rnjng Guest
    Also, why is the water clear...is that normal? Does algea cause water to turn green, then settle at bottom and then water clears???
    Shock it 'til it's dead and then vacuum. And then make sure you're keeping adequate Cl levels in the pool so it doesn't come back.
    Is your pump running now? When you start to circulate your water I expect it will turn quite green. Either way, follow Janet's advice and shock it. Go over the algae thread and do some reading, or the chlorine thread to see the multiple questions and responses about how to completely kill the algae. If you want specific advice for your pool you need to post test results and basic information about your pool so people can help. Good luck :-)
    rnjng Guest
    yeah, I haven't had a chance to test water yet. but I know he levels are scary low. but I need to start the pump andstart the bbb method, but 1st need more bleach, tks!!!
