Re: Too much suction !!
Ok guys ---thanks for all the input but honestely we do have too much suction. Hubby actually bent the pole trying to get the head unstuck. Also you are talking to a real dummy here. As you can guess this is our first season of maintaing our pool on our own so we have lots to learn and we sure do appreciate your help.The pump is an AquaTool Sand filter,Stay -rite
dyna Glass with RPM of 3450- tank says 300lbs. I have no idea about what I just wrote--that is just what it says on the tank. Thought maybe it might help you guys.
To vacuum we put this black disc in the skimmer and attach the hose filling it with water. The head is attached at the end of the hose that we put in the pool. Keep water pressure about 15--if it starts to rise we backwash. The only thing we have not been doing is rinsing MAYBE that is the problem!! Could the sand be too dirty? Water is dirty when backwash but clears right up in few min. Should I be rinsing after I backwash??
Duraleigh you suggested restricting the ball valves on the pressure side of the pump---How do you do this (told you I was a dummy)
Please keep the suggestions going--ALL help is appreciated
Karen
