Thread: Salt build up on stone and stamped concrete
    Jul 2006
    Post Salt build up on stone and stamped concrete
    How can I remove the salt build up on my stone wall for my water fall and on the stamped concrete. Without causing any damage???
    duraleigh Guest
    Default Re: Salt build up on stone and stamped concrete
    If it's salt, it should dissolve in water. If not, you probably got calcium buildup. Mild muriatic acid (usually less than 10%) will normally dissolve calcium buildup. Rinse it with clear water as soon as the calcium is gone.
