Re: water loss
You will need to do the bucket test to find out if you have a leak.
Telling you that 1" is normal under those or any other conditions is fruitless since that would just be a big guess with way too many variables in the equation. 100 deg. with high humidity and no wind would yield completely different results than 100 deg with low humidity and a good breeze.
