Re: CYA not showing yet.
I'm using a 200 lb sand filter. From reading the Forum I knew not to backwash the filter after adding the CYA to the skimmer. So, I haven't done that yet. Here is a website showing what I bought from Wal-mart (item I bought is towards the bottom). It's entitled: 4 LB, HTH, Stabilizer & Conditioner, Cyanuric Acid, Reduces Chlorine Loss Due To Intense Sunlight. - Weight 4.0 Lbs. Item#: 61305
http://www.unclejoes.com/Pool%20Chem...For%20Less.htm
I think I might backwash and put some in a sock. I've read about that on the Forum, but I thought thru the skimmer would be less of a hassle. Is there a chance that the CYA from Wal-mart is old and not any good?
