Thread: Bleach In Skimmer
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Bleach In Skimmer
    I have a cartridge filter and want to know if adding bleach through the skimmer will damage the cartridge? Is it more effective to add the bleach directly to the pool?
    John
    Default Re: Bleach In Skimmer
    I would just put the liquid chlorine (bleach) directly into the pool, at the deep end near a return jet. Is there a particular reason you wanted to put it into the skimmer? See my post
    Party Blue
    where I did an experiment that showed the spreading of chlorine throughout the pool would probably be very fast. If you were worried about that, you could always add some (say, one-third) directly to the shallow end as well.
    Richard
    My pool is all the same depth. Some here say they add their bleach through the skimmer, I was just wondering if it could cause damage to a cartridge filter.
    John
    Like Richard, I also add it directly to my pool, in front of returns. I usually add a half gallon +/- at a time and divide that by three, 1/3 for each return I have. Now Richards experiment with the blue stuff got me thinking (always a dangerous thing) so I will probably start to add 2/3 at the deep end return and the rest at the two returns in the shallow end. To be honest, I don't think it really matters one one or the other. I have read excellent arguments for adding bleach both ways. It shouldn't hurt your filter if you decide to add directly to the skimmer.
    Dave
  1. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  2. Which skimmer
    By rayh78 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2009, 08:15 PM
  3. Adding Bleach w/CYA in skimmer?
    By JJParrish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2007, 04:46 PM
  4. Adding bleach to the skimmer
    By trauh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 03:07 PM
  5. Skimmer
    By GreenWater in forum Above-Ground Pool Construction & Repair
    Last Post: 05-31-2006, 11:39 PM
