Results 1 to 10 of 14
Thread: shock to bleach comparison
    Renee C is offline ** No working email address ** Renee C 0
    Jul 2006
    Default shock to bleach comparison
    How does bleach compare to shock. Is 1 gallon of bleach the same a 1 lb of shock? or does it compare differently?
    Morris, IL
    Default Re: shock to bleach comparison
    If I remember correctly yes it is the same.
    Jul 2006
    after adding bleach how long do you need to let your filter run?
    Is it safe to swim after adding bleach? How long do you have to wait?
    Morris, IL
    You have to wait like less than one minute. Possibly even in the area of five seconds.
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Hi Renee,
    I know what you are asking about. It's sort of misleading of the makers calling it "shock" . Its really just the same stuff you can buy in 25lb container , most of the time its calcium hypochlorite.
    Its better to think of "shock" as a verb . THe Act of raising CL levels to "shock" the pool. And good ol bleach does just fine at it
    duraleigh Guest
    Renee/Sevver,
    Calcium Hypochlorite is normally 65% - 68% available chlorine.....bleach is 6%. They absolutely do not equate.
