Re: shock to bleach comparison
You have to wait like less than one minute. Possibly even in the area of five seconds.
Hi Renee,
I know what you are asking about. It's sort of misleading of the makers calling it "shock" . Its really just the same stuff you can buy in 25lb container , most of the time its calcium hypochlorite.
Its better to think of "shock" as a verb . THe Act of raising CL levels to "shock" the pool. And good ol bleach does just fine at it
Renee/Sevver,
Calcium Hypochlorite is normally 65% - 68% available chlorine.....bleach is 6%. They absolutely do not equate.
As for raising the Cl levels, they are equal though right?
If I understand Duraleigh's post you need 6x the amount of bleach to equal the regular shock.
And I guess you would to have wait at least 24hrs before swimming in such a highly chlorinated pool.
Duraleigh or CToon please respond.
Yes, but the amounts vary, just because the concentrations are different does not mean that the small bag of shock added to the pool would not change the Cl levels the same amount as a gallon of bleach. Sorry, but this is what I thought, I know I read it here somewhere...
Sevver,
I misspoke. They are closer than I assumed. According to the info I have, 1lb of Cal Hypo will have about 25% more chlorine than 1 gallon of chlorine. I assumed (there's that word, again) the spread was far greater and I should not have been quite so adamant.
But what effect do they have in the end? That is what I am getting at. The concentrations are different, but the quantities are not the same either, so you really cannot compare them like that, what change do they make on the chemistry of the water?
Wow! We've sorta' hijacked the thread but to clarify a little:
1 lb of Cal Hypo will raise Cl 8ppm in a 10k pool
1 gal of 6% bleach will raise the same pool 6ppm
With bleach, you get almost nothing unwanted except a little salt
With Cal Hypo, you'll add a fairly good amount of Calcium which you may or may not want.
