Results 1 to 8 of 8
Thread: Baking Soda How To Add
    mbar's Avatar
    Ashland, PA
    Default Re: Baking Soda How To Add
    duraleigh,
    Wouldn't you have to raise the alkalinity first with baking soda, this way you can see how high your ph went, then adjust the ph with borax? This way if the alkalinty is right, and your ph goes a little high, you can just lower it with a little acid. Please correct me if I'm wrong, I'm still trying to get it all straight.
    Northeast PA
    duraleigh Guest
    Hi, Marie,
    I'm "pontificating" from memory so take all this with a grain of salt. I'm fairly sure Ben recommends pH adjustment first. If you do the Alk first, it makes it somewhat more difficult to adjust pH because of the increased buffering.
    As you know, when one moves, the other typically moves with it so the recommendation to do it incrementally should be adhered to.
    I have adjusted my water from 6.8pH and 30 Alk three times. Each time I was able to adjust the pH to 7.3 and then bring the Alk up (the next day) to 90. I saw no increase in pH with the Alk adjustment tho I know I should have. I can't explain why but that's the affect I got.
    mbar's Avatar
    Ashland, PA
    Thanks so much! I know there are strange ways to do the chemicals in pools that aren't always obvious. I will make note of this, and use this method in the future. That's why I love this forum!
    Northeast PA
