Re: New Vac head
My Hayward Super Vac needed replacing, so I bought this one
Notice the brushes set at different angles. Very good for picking up bugs and leaves off the bottom, but it is way too light, and it doesn't clean very well right at the point where the angled edges of the hopper meet the bottom, which is where most of my dirt is. This might be decent for a pool without the hopper.
I got another Super Vac on eBay. The Super Vac differs from the one pictured above in that the brushes are around the outer edge only. It also allows for adding up to 3 lbs of lead weights. Downside to the Super Vac is that it tends to push larger debris around because it doesn't have gaps in the brushes. I'm not sure the Super Vac is made anymore, because I couln't find it anyplace but eBay. It is around $35 to $40, and that often doesn't include the weight kit. I couldn't find a weight kit or replacement brushes either one for the Super Vac, but I just used the weights from my old one.
