Re: While my pool lies in WAIT ...
Your alk is a little high--normally in a vinyl pool I'd say not to be too concerned about it, but with a high calcium level, you're going to have to be careful to keep your pH down to keep the calcium from milking up your pool. For now, leave it alone--but if you start having cloudiness problems, after drain/refilling to lower your calcium, your alk would be the next thing to adjust. I wouldn't use any cal-hypo to chlorinate with--you don't want your Calcium any higher!
