Closed Thread
Thread: How much water?
    SPitz Guest
    Default How much water?
    Our gunite is complete I know we have to water the gunite frequently, but is there such a thing as watering too much? What do you consider frequent? Once....twice...three times a day or sit out in a patio chair with the hose and a cooler full of beer all day?
    Thanks in advance!
    mas985's Avatar
    Pleasanton, CA
    Default
    Depends on how hot it is but you really cannot over water it as far as I know. If it dries pretty quickly then 3-4 times a day. If it stays wet all day, then probably once a day is ok.
    Mark
    KurtV is offline Registered+ Widget Weaver KurtV 0
    Mandeville, LA, USA.
    Default Watering device
    Here's a little thing I rigged up to take the drudgery out of gunite watering. It's just half inch pvc, standard fittings, and some sprinkler heads ($20 and 30 minutes). Put it on a hose end timer and you really don't have to do anything.
    VA, USA.
    Default were is the fun
    I love Kurts system. But to be honest I loved spraying my pool. I was out there anyway every 30 minutes to look at it. So spraying it was fun.
    I also don't think you can over do it.
    Guido
    MarkC is offline Registered+ Weir Watcher MarkC 1 star
    Default
    My builder left a sprinker in the pool and is was going 24/7 for 5 days. He left the plug out of the main drain so the water drained out. That might have been overkill.
    Scottsdale, Arizona
    Default
    Quote Originally Posted by SPitz
    best option I've seen so far
    captainx is offline ** No working email address ** captainx 0
    Default
    We have had a gunite pool in my backyard unfilled for about 2 months waiting on our addition construction to be finished but no one said anthing about watering it. I live in Florida, so no rain.
    Is this a problem?
Closed Thread
